be sure to start a thread in the froum and keep us posted with many, many pics!Kevino wrote: I will begin building within the month. A Guillemont Night Heron.
kayak building foto journal
I will. Everyone really helped me out last time with my first build (a Great Auk - like yours, Jimbo, but not as intricate a design). Come to think of it, I don't think I've posted a final picture of the boat in the water. I'll do that when I get home.jimbo wrote:be sure to start a thread in the froum and keep us posted with many, many pics!Kevino wrote: I will begin building within the month. A Guillemont Night Heron.
This time I want to take more time and be extra careful. Silverio sets the bar so high.
The plans have now been ordered...
- jimbo
- Real Name: Jim Raymonda
- Kayaks: 14' auk, Rachel boat, The "quick and dirty"
- Contact:
yeahKevino wrote: Silverio sets the bar so high.
- amlap
- Real Name: Silverio Palma
- Kayaks: Ross (KF) - Exquisit (OI) - Enigma (Gleenlander) - Squalus
Hi folks,
I've been reading with a big smile on my face.
No, not because I'm the king
(one spanish guy called my eminence)
I'm smiling because this post influenced one good member wanting to build another kayak. I did enjoy Kevino's last experience.
What I can say is this: By that time I think I will have finished the Exquisit. It will be great to sit back and see all you struggling to do your best. I've put the bar high?
The builder who comes next always thinks like that. What about Ross, Glen, Miklos, Anewhouse, Barry Upton and many others skilled members?
I think we will have a good Fall and Winter building season here.
Ahhhh....and we cannot forget our friend that is hibernating too.
Yeap.. I think this forum is worth it
- Islandpaddler
The space shuttles are about to be decommissioned. I don't think anybody will be able to get over that bar now!amlap wrote: I've put the bar high?![]()
Give you 6 months before the building withdrawal symptoms get so bad you will be onto your next one. There is no cure for this addiction, not that I would seek a cure out!
- amlap
I´ve finished striping the deck.
I did the sanding with a ROS but could not sand where the cradle was, so I had to take it off. I will have to sand it slightly and put it back in position to give a final sanding with a 120grit fairing board.
In the meantime I filled some minor gaps with PVA glue mixed with wood dust.
I asked my wife to help lift the deck because I thought it had some weight. I was surprised that I lift it with a finger. If I was to guess, it would be about 1kg. Just couldn't believe it.
I might give a sealer coat tomorrow.
It is very fragile so I will have to give 2 coats of fiber under the deck.
- Islandpaddler
- Islandpaddler
Just an aim for an ultra light stripper. Most 1st time kayaks weigh in at around the 18 to 20kg mark. Their next builds range from 14 to 18kg's. Main reason is that their workmanship especially glassing techniques improve. These weights are for a 17 to 19 foot fitted out sea kayak.
With good workmanship and only the bare minimum of epoxy I am of the opinion that a 10kg or under kayak could be built. This kayak would be lighter then commercial kevlar / Carbon fibre yaks yet because of the composite nature of a wooden kayak it will be stronger.
I would think a wood lighter then WRC will need to be used (Paulownia for example) to get this target but it may just be doable with WRC.
Robin will have to verify but if I remember correctly a few of his Paulownia yaks are around the 12kg mark???
By the way, I don't think lighter is better. An ultra light kayak blows around in the wind more, not only when paddling but chasing a kayak tumbling down the beach is not a good look!
- amlap
Islandpaddler, I'm 4 times stronger than I thought or have not weight sensibility. The barewood deck weighs 4,1kg. Still it's a good figure.
Balsa...I read that balsa is not good for kayaks. Apart beeing expensive it is weak and very flexible. You would save weight using balsa but then you would have to reinforce it with fiber. The amount of fiber to have a decent stiff kayak would prob. be heavier than using cedar. Don't tell me that the core is not relevant as some builders say because it is too.
I epoxy sealed the deck and it looks ok.
Here are some pictures.
Pic. 4
Remember the srew in the diamond? I filled it with a cedar straw
Pic.5
Natural 3mm dark spot.
Pic.7
I left a small area with glue not fully sanded just to see the result.
You can see a phantom white area. No problem! That area is going to be cut out for the cockpit
Silvério
Pic. 4
Pic.5
Pic.7
Silvério
- Islandpaddler
Nice Silvério, very very nice... Its going to be hard to bring yourself to attack it with a jig saw to cut out the cockpit!
Foam and honeycomb cores are commonly used on commercial boats. Neither of these have structural strength by themselves until they are sandwiched between 2 stiffer materials. But they need thicker "walls" (more glass or CF etc) then we do with wood to obtain the same impact strength.
We commonly use Paulownia over here instead or in conjunction with Cedar. Paulownia is 1/2 the weight of WRC but is cheaper and easier to work with. Despite being softer then WRC I have not noticed any difference with rock collisions in the Paulownia areas on the hulls compared to the WRC areas.
Balsa may be going too far though. Doable but would recommend extra layers of glass - which of course increases the weight.....
